cgal-discuss - [cgal-discuss] Uneven implicit surface result
  • To:
  • Subject: [cgal-discuss] Uneven implicit surface result
  • Date: Fri, 14 Aug 2009 14:20:57 +0100
  • Organization: OpenCFD Ltd.
Hello,
I'm meshing surfaces using the implicit surface mesher and testing it with
simple smooth shapes. Using the example
examples/Surface_mesher/mesh_an_implicit_function.cpp
I've created a fairly fine surface of a sphere using the criteria:
30.0, // angular bound
0.01, // radius bound
0.001 // distance bound
The surface is not smooth - it has an "orange peel" look. Plotting the
radius
of each vertex of the triangulation shows the magnitude of error of the
triangulation point positions from the expected radius of 1:
Creating a coarse surface with criteria
0.1, // radius bound
0.1 // distance bound
Results in:
where the magnitude of vertex error is similar, but in the fine case, the
same
radial vertex position error in a smaller triangle creates a bigger error in
the normal direction, hence the uneven look.
Is this the result that is expected? and is there anything that I can do to
improve the conformance of the triangulation points to the expected sphere
function? Am I missing a tolerance adjustment somewhere?
It isn't a write precision/truncation problem, as I've set the precision of
the ofstream to 15.
Thanks,
Graham
Attachment: coarseSphereSurfaceWithRadius.png
Description: PNG image
Attachment: fineSphereSurfaceWithRadius.png
