- To:
- Subject: Re: [cgal-discuss] Performance of AABB Tree versus bipartite box intersection
- Date: Mon, 17 Aug 2009 14:22:03 +0200
On Monday 17 August 2009 13:30:15 Andre Massing wrote:
> Hi again,
> thanks for the reply!
> On Monday 17 August 2009 12:13:27 Laurent Rineau (GeometryFactory) wrote:
> > On Monday 17 August 2009 11:40:14 Andre Massing wrote:
> > > Hi all,
> > > I am working on intersection of overlapping meshes, used in a certain
> > > finite element method. Since the upcoming CGAL 3.5 release will offer
> > > an additional package implementing an AABB Tree
> > > http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/AABB_tree/Chapter_m
> > >ai n. html I am wondering how it compares to
> > > http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Box_intersection_d/
> > >Ch ap ter_main.html .
> > > Since I am going to intersect two meshes (which could contain many
> > > cells) I am thinking to use the bipartite version of the
> > > CGAL::box_intersection_d function.
> > > http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/Box_intersection_d_
> > >re f/ Function_box_self_intersection_d.html#Cross_link_anchor_1587
> > > Would this function be (theoretically) faster than building up a tree
> > > of the first mesh and query each bbox of the 2nd mesh via
> > > http://www.cgal.org/Manual/3.5/doc_html/cgal_manual/AABB_tree_ref/Class
> > >_A AB B_tree.html by simply iterating through the bounding box list of
> > > the 2nd mesh? I could imagine that in the bipartite case some
> > > performance tweaks are used?
> > I think Box_intersection_d is more appropriate when you want to intersect
> > two given surface meshes. The AABB tree query times are great but the
> > construction time of the tree will penalize the total computation time.
> Hmm, ok, even I don't use distance and don't call
> accelerate_distance_queries? In the intended application there will be one
> fixed background mesh and another moving mesh, which means that I have to
> compute the intersection with the background mesh at each single time step.
If you have a fixed mesh and a lot of queries on it, then the AABB will
probably be the better solution.
> This rises also another question. Since there might be some grid
> refinement/coarsing, is there any opportunity to successively supplement
> either the tree or the (sorted) list of bounding boxes by new boxes? Or do
> I have to reinit the whole thing?
The modification of the AABB tree is not doable for the moment. That is a
difficult task in my opinion. Maybe the authors of that package will reply on
that point and contradict me. Let's hope so.
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Performance of AABB Tree versus bipartite box intersection, Andre Massing, 08/17/2009
- Re: [cgal-discuss] Performance of AABB Tree versus bipartite box intersection, Laurent Rineau (GeometryFactory), 08/17/2009
- Re: [cgal-discuss] Performance of AABB Tree versus bipartite box intersection, Andre Massing, 08/17/2009
