- To:
- Subject: Re: [cgal-discuss] Regular triangulation with info
- Date: Mon, 17 Aug 2009 14:11:19 +0200
Hello 400555,
I am on the potential-answerer side of the mailing list, and I
would be glad if people who post mails put their name, even if
their administrators give them strange email addresses.
Think yourself: Would you reply to someone called 400556 ?
best regards,
andreas
400555 wrote:
Thank you for answer!
Could you answer on the 1st part of the question also (about hidden vertices) ?
Regards.
On Thu, Aug 13, 2009 at 4:57 PM, Sylvain Pion < <mailto:>> wrote:
400555 wrote:
Thank you for answer !
Manuel, I checked out hidden vertices number - no any hidden
vertices at all.
Also I read manual but still don't understand when vertex could
become hidden, could anyone explain it in easy words or show an
example.
/Manuel wrote: Also maybe you profit from some optimizations in
Delaunay triangulation../
/Manuel, what kind of optimization do you mean? Inside of CGAL
engine or on my side? On my own side I don't do any
optimization. All what I do - just insert list of points one by
one and apply info for each of them./
/Sylvain wrote: The lack of static filters for the power tests.../
I don't get what does it mean? And is it possible to avoid it?
Sorry for many questions.
Thank you for answerers.
I am afraid it is all on CGAL's side, there is not much you can do
easily.
Obviously Regular cannot be faster than Delaunay, but the slow down
factor could be greatly reduced. It just needs some work, which has
not been done yet.
-- Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
-- You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Regular triangulation with info, (continued)
- Re: [cgal-discuss] Regular triangulation with info, Sebastien Loriot, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/12/2009
- Re: [cgal-discuss] Regular triangulation with info, Manuel Caroli, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, Sylvain Pion, 08/13/2009
- [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Delaunay triangulation 3, Sebastien Loriot, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/13/2009
- Re: [cgal-discuss] Regular triangulation with info, 400555, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Andreas Fabri, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Vitaliy, 08/17/2009
- Re: [cgal-discuss] Regular triangulation with info, Vitaliy, 08/19/2009
