- To:
- Subject: Re: [cgal-discuss] Convex Hull problem
- Date: Sat, 22 Aug 2009 17:38:52 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=ZlA/u1Nfu3cMmn9x6O1tnQ2QUZxsZJ0Let20vsSZhyhKhLPQo2IXizkQaacH0ZgHs/ fOA/L/Kvtigt2OXXjpi/c+k2GJV+SxbXdlvXlg1u5Oe/9+Gvltj9X3wnKTGtAFYZMsHi mSVgDmbj8iro/+JEom5euDHQ85uoZxlWo3Cew=
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-03/msg00265.html
if this helps...
-Atul
On Sat, Aug 22, 2009 at 5:28 PM, Leandro Gazoni <> wrote:
Dear Friends,
Would like to take this option in my code because I will take these data to include more points in the radius of these coordinates.
Gazoni2009/8/22 Atul Thakur <>
If you just want to write it to a file for reading...easiest way without changing your code is that you can redirect the output to a file.
Like on windows you can give this command...
yourapplication.exe >>output.txt
-AtulOn Sat, Aug 22, 2009 at 4:46 PM, Leandro Gazoni <> wrote:
Hello,
I have the problem!!!
I have a procedure that returns a list of vertices of the convex hull, I would like to save this list in a file and then read this list again. How to save this list in a file?
In the terminal I can see the output of the vertices, example:
Pontos do Convex Hull sao:
-965 497 803 1
-909 -199 -201 1
-905 303 -378 1
-455 -738 995 1
-623 -966 -322 1
205 -948 -8 1
-853 -625 -69 1
-986 -59 225 1
925 -738 515 1
void List_CH(Polyhedron_3 Poly) {
/* CRIANDO ARQUIVO DOS PONTOS DO CONVEX HULL */
string line;
fstream fgrava;
fgrava.open("CH_Gerado.txt");
/* PONTOS DO CONVEX HULL */
Polyhedron_3::Vertex_iterator vi;
std::vector<Point_3> ret;
if (!Poly.empty()) {
vi = Poly.vertices_begin();
//fa = Pcvx.facets_begin();
std::cerr << "Pontos do Convex Hull sao:" << std::endl;
for (; vi != Poly.vertices_end(); vi++) {
Polyhedron_3::Vertex v = *vi;
ret.push_back(v.point());
std::cout << v.point() << std::endl;
while (fgrava.eof()) {
getline(fgrava, line);
cout << line << endl;
fgrava.seekg(0, ios::end);
fgrava << v.point() << "\n";
fgrava.close();
thanks
Leandro Gazoni
Leandro Gazoni
- [cgal-discuss] Convex Hull problem, Leandro Gazoni, 08/22/2009
- Re: [cgal-discuss] Convex Hull problem, Atul Thakur, 08/22/2009
- Re: [cgal-discuss] Convex Hull problem, Leandro Gazoni, 08/22/2009
- Re: [cgal-discuss] Convex Hull problem, Ariel Baez, 08/22/2009
