cgal-discuss - RE: [cgal-discuss] Knowing which voronoi vertices are inside a polygon
  • To: <>
  • Subject: RE: [cgal-discuss] Knowing which voronoi vertices are inside a polygon
  • Date: Sun, 23 Aug 2009 14:53:27 +0300
I forgot to mention that the segments form polygons, and so "inside" means
in the inner area of the polygon. I finally did it with the construction of
an arrangement, but I wish there was some better way to extract the actual
inner medial axis.
Amir.
-----Original Message-----
[mailto:]
Sent: Friday, August 21, 2009 12:45 PM
To:
Subject: Re: [cgal-discuss] Knowing which voronoi vertices are inside a
polygon
On Wed, Aug 19, 2009 at 15:30, Amir
Vaxman<>
wrote:
> I may be that this question was answered here in the past, but I can't
find
> the answer: given a Voronoi diagram of 2D segments, how do I predict which
> vertices are inside and which aren't?
Could you explain what is the "vertex" you refer to (site or a Voronoi
vertex)? And what do you mean by "inside"?
~ash
