- To:
- Subject: Re: [cgal-discuss] rendering CGAL objects in Qt
- Date: Fri, 28 Aug 2009 12:09:32 +0200
That is interesting idea, thank you for this hint!I'm just not sure how could I draw it in correct way.
In case, that I would have in arrangement just line segments it would be
easy, but if I have curved lines I can get source and target of the curve
easily, but how to draw curved line between start and end points correctly?
I still can't find any suitable Qt object for this drawing.
If you cannot draw the curve as is, then you need to approximate it with a polyline and draw the linear segments that comprise the polyline. Some of the traits classes in the arrangement package contain an operation that does the approximation.
I just wonder if this approximation is needed also in case, when I put in arrangement circle. As I know circle is in arrangement divided in two X_monotone_curve objects. Then when I want to fetch it from arrangement and draw it - isn't there any more straightforward solution than approximation?
Best regards and thx a lot for answer
Martin
On Fri, Aug 28, 2009 at 11:28 AM, <> wrote:
Quoting "Martin Baroš" <>:If you cannot draw the curve as is, then you need to approximate it with a polyline and draw the linear segments that comprise the polyline. Some of the traits classes in the arrangement package contain an operation that does the approximation.
I think so. As far as I know, there is not graphics view item for
arrangement.
You'll need to draw each curve of the arrangement one by one.
Thank you for your answers, I really appreciate that.
Martin
On Thu, Aug 27, 2009 at 10:26 AM, Laurent Rineau (GeometryFactory) <
> wrote:
On Wednesday 26 August 2009 16:10:54 Martin Baroš wrote:R&D <http://www.cgal.org/%0AR&D> Engineer at GeometryFactory
> Hi,
> thank you for your answer.
> I'm using Qt Graphics View framework and I can draw geometric objects
> without problems.
> But I'm still not sure how to draw content of arrangement - should it be
> done by fetching X_monotone_curve one by one from arrangement and then
> drawing in Qt scene?
arrangement.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.geometryfactory.com/
--You are currently subscribed to cgal-discuss.
- [cgal-discuss] rendering CGAL objects in Qt, bar_ma, 08/15/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, bar_ma, 08/15/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Laurent Rineau (GeometryFactory), 08/17/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Martin Baroš, 08/26/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Laurent Rineau (GeometryFactory), 08/27/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Martin Baroš, 08/28/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, efif, 08/28/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, efif, 08/29/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Martin Baroš, 08/29/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Laurent Rineau (GeometryFactory), 08/28/2009
- Re: [cgal-discuss] rendering CGAL objects in Qt, Zohar Levi, 08/28/2009
