cgal-discuss - Re: [cgal-discuss] rendering CGAL objects in Qt
  • To:
  • Subject: Re: [cgal-discuss] rendering CGAL objects in Qt
  • Date: Fri, 28 Aug 2009 11:01:48 +0200
I think so. As far as I know, there is not graphics view item for arrangement.
You'll need to draw each curve of the arrangement one by one.
I'm just not sure how could I draw it in correct way.
In case, that I would have in arrangement just line segments it would be easy, but if I have curved lines I can get source and target of the curve easily, but how to draw curved line between start and end points
correctly? I still can't find any suitable Qt object for this drawing.
Thank you for your answers, I really appreciate that.
Martin
On Thu, Aug 27, 2009 at 10:26 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Wednesday 26 August 2009 16:10:54 Martin Baroš wrote:
> Hi,
> thank you for your answer.
> I'm using Qt Graphics View framework and I can draw geometric objects
> without problems.
> But I'm still not sure how to draw content of arrangement - should it be
> done by fetching X_monotone_curve one by one from arrangement and then
> drawing in Qt scene?
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D
Engineer at GeometryFactory
http://www.geometryfactory.com/
