cgal-discuss - Re: [cgal-discuss] Squared Radius
  • To:
  • Subject: Re: [cgal-discuss] Squared Radius
  • Date: Fri, 28 Aug 2009 17:42:45 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=rh9xafybH9WuRi681RWQA2dYP6fvQgD4ycG7tTdaFuqn5ds7hnJ9kmVuUQVpAOCaDM 71wWKeoHPbMe+Yd8FAx/YhGrusv4RJdnJGeWNblgrEveKJwmTTC9xe1AX5Q1DdFtJymp NhG1BofuQ6R/7DIwsg89+dsUNxktw+2OTf6K0=
I am using the  CGAL::Filtered_kernel<CGAL::Cartesian<double> > kernel.
On Fri, Aug 28, 2009 at 5:27 PM, Ben Supnik <> wrote:
What Kernel are you using?
Panagiotis Foteinos wrote:
Hello everybody.
I observed something strange.
If a triangle t(p, q, r) is close to a degenerate one with the value, however, of the predicate t.is_degenerate() always being FALSE, then during the calculation of CGAL::squared_radius(p, q, r), the assertion:
  terminate called after throwing an instance of 'CGAL::Assertion_exception'
 what():  CGAL ERROR: assertion violation!
Expr: ! CGAL_NTS is_zero(den)
File: /scratch/local/CGAL-3.4/include/CGAL/constructions/kernel_ftC2.h
Line: 60
is trigerred, and the calculation fails.
Unfortunately, this error is difficult to be reproduced, but sometimes it happens.
Is this behavior expected? Is it relevant to the fact that the triangle is almost degenerate?
Thank you,
Panagiotis
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
