- To:
- Subject: Re: [cgal-discuss] Squared Radius
- Date: Fri, 28 Aug 2009 17:49:50 -0400
The experts will correct me I am sure, but ...
This is an exact predicate, inexact construction kernel.
If I understand correctly, this kernel can tell you IF the triangle is degenerate, but if it is not degenerate it might still NOT be able to calculate the area properly, since the underlying numeric type (double) can round out.
Try using CGAL::Quotient<CGAL::MP_Float> instead of double...if things get better maybe it's a construction issue?
cheers
ben
Panagiotis Foteinos wrote:
I am using the CGAL::Filtered_kernel<CGAL::Cartesian<double> > kernel.
On Fri, Aug 28, 2009 at 5:27 PM, Ben Supnik < <mailto:>> wrote:
What Kernel are you using?
Hello everybody.
I observed something strange.
If a triangle t(p, q, r) is close to a degenerate one with the
value, however, of the predicate t.is_degenerate() always being
FALSE, then during the calculation of CGAL::squared_radius(p, q,
r), the assertion:
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: ! CGAL_NTS is_zero(den)
File:
/scratch/local/CGAL-3.4/include/CGAL/constructions/kernel_ftC2.h
Line: 60
is trigerred, and the calculation fails.
Unfortunately, this error is difficult to be reproduced, but
sometimes it happens.
Is this behavior expected? Is it relevant to the fact that the
triangle is almost degenerate?
Thank you,
Panagiotis
-- Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
<mailto:>
Developer mailing list:
<mailto:>
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Squared Radius, Panagiotis Foteinos, 08/28/2009
- Re: [cgal-discuss] Squared Radius, Ben Supnik, 08/28/2009
- Re: [cgal-discuss] Squared Radius, Panagiotis Foteinos, 08/28/2009
