- To:
- Subject: [cgal-discuss] Switch of hidden points check
- Date: Sun, 6 Sep 2009 19:39:53 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=OnL45UxNFzvtcJ2uPLwU8apqPftv+tUIRpyPJ+CraGoV26xhNFKDgtPeB2uFZbDh0N QpgnHMA5N2QJ5PWuVOJ591hHnG/v0JxdK4OOcfu1QqLuTQgX4U7okENeCQiex34Bokqj a0autWz8VZ71c4TI/i5TaqLmXJrJOEGOJ7Lz8=
Hello !
For regular triangulation, I need to switch off hidden point check.
Because it affects to time performance.
And for my data I know exactly that there are no any hidden point.
Do you know how can I do it ? ...where in source code of CGAL I can switch it off ?
Thank you.
Vitaliy.
- [cgal-discuss] Switch of hidden points check, Vitaliy, 09/06/2009
- [cgal-discuss] Re: Switch of hidden points check, Vitaliy, 09/14/2009
- [cgal-discuss] Deprecated include from boost::property_map, Robert Patro, 09/14/2009
