- To:
- Subject: [cgal-discuss] straight skeleton errors when using inexact ctors
- Date: Mon, 07 Sep 2009 00:55:07 -0400
Hi Y'all,
I have a general polygon set that I want to calculate a striaght skeleton for. Due to the complexity of the layout, I tried the trick of using an eact pred/inexact construction kernel, then convert.
But when I do this I get a clearly bogus skeleton...skeleton edges crossing each other and going outside the polygon area entirely. Using the exact pred/exact construction kernel does not have this problem (but is 48 times slower).
Now here's the confession: the polygon boundaries come from boolean operations on a general_polygon_set, and the input data is _not_ very good. I'm having to round down via CGAL::to_double to input curves into the inexact kernel, and it is possible that I am creating a bogus contour that way. :-(
But...when I run polygon_2.is_simple() on the input curves, they all say they're fine. And some of the areas that have a broken skeleton look not-very-complex to me...they shouldn't be up against the limits of precision.
Any hints as to what's going on? This is an off-line process so I can just use the slow kernel, but the processing time is going to get a bit out of control.
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] straight skeleton errors when using inexact ctors, Ben Supnik, 09/07/2009
