- To:
- Subject: Re: [cgal-discuss] CGAL::do_intersect
- Date: Tue, 08 Sep 2009 11:48:49 +0200
Gmain wrote:
Hi all,
I´m using CGAL::do_intersect(Kernel::Triangle_3 T1,Kernel::Triangle_3 T2) as a
test before starting the real intersection process.
My Kernel is:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
My Question: Is the result of the function CGAL::do_intersect exact or do I
need to take:
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
as Kernel?
Hi.
You might want to look at this thread (similar question for segment-triangle-intersections):
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-07/msg00038.html
In essence, if you only need the do_intersect to yield perfectly exact results, the inexact_constructions_kernel will suffice, but you might get unpleasant results when performing the actual intersections afterwards.
Cheers,
Alexander
- [cgal-discuss] CGAL::do_intersect, Gmain, 09/08/2009
- Re: [cgal-discuss] CGAL::do_intersect, Alexander Kobel, 09/08/2009
- Re: Re: [cgal-discuss] CGAL::do_intersect, Gmain, 09/08/2009
