- To:
- Subject: Re: Re: [cgal-discuss] CGAL::do_intersect
- Date: Tue, 8 Sep 2009 11:57:19 +0200 (CEST)
>Hi.
>You might want to look at this thread (similar question for
segment-triangle-intersections):
>https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-07/msg00038.html
>In essence, if you only need the do_intersect to yield perfectly exact
results, the >inexact_constructions_kernel will suffice, but you might get
unpleasant results >when performing the actual intersections afterwards.
>Cheers,
>Alexander
Tx Alexander,
your info was perfect.
Cheers,
Martin
- [cgal-discuss] CGAL::do_intersect, Gmain, 09/08/2009
- Re: [cgal-discuss] CGAL::do_intersect, Alexander Kobel, 09/08/2009
- Re: Re: [cgal-discuss] CGAL::do_intersect, Gmain, 09/08/2009
