cgal-discuss - Re: [cgal-discuss] missing intersection detection for some combination of primitives ?
  • To:
  • Subject: Re: [cgal-discuss] missing intersection detection for some combination of primitives ?
  • Date: Wed, 09 Sep 2009 10:58:36 +0200
A small question has remained..
Sylvain Pion wrote:
Hi Andre,
Andre Massing wrote:
first of all, I want to thank the developer behind the CGAL project for providing such a well-documented, open-source computational geometry library. We just started to use it in our mesh classes of our FEM library dolfin for providing some intersection detection and computation, and it is actually quite fun to work with.
Excellent !
Since we intend to use intersection quite heavily I have been wondering, why certain intersection test in 3D have not yet been implemented, such as the following
‘do_intersect(Point_3&, Point_3&)’
primitive_intersection_test.cpp:79: error: no matching function for call to ‘do_intersect(Point_3&, Segment_3&)’
primitive_intersection_test.cpp:81: error: no matching function for call to ‘do_intersect(Point_3&, Tetrahedron_3&)’
primitive_intersection_test.cpp:84: error: no matching function for call to ‘do_intersect(Segment_3&, Segment_3&)’
primitive_intersection_test.cpp:86: error: no matching function for call to ‘do_intersect(Segment_3&, Tetrahedron_3&)’
primitive_intersection_test.cpp:93: error: no matching function for call to ‘do_intersect(Tetrahedron_3&, Tetrahedron_3&)’
in particular the Point_3/another primitive are missing. Is there any special reason for that, a principle obstacle for implementing this correctly or do I just not use the right functions?
For do_intersect(Point_3 p, X x), x.has_on(p) provides a similar functionality.
There exists a Triangle_3_Point_3_do_intersect function in CGAL, which seems at a first glance not rely on the x.has_on(p) function. Is there any special reason for that?
For do_intersect(Point_3, Point_3), operator== should obviously do it.
It's true that we could envision generalizing the do_intersect()
to also handle these cases.
I just wonder, since for instance a Triangle_3 Tetrahedron_3 or Triangle_3 Triangle_3 intersection or intersection those objects with Bbox are implemented.
At a first glance at
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Kernel_23_ref/Function_do_intersect.html
opposed to the 3D case, the 2d case seems fairly complete.
Maybe you could give me some hints or pointers, how one might supply these additional tests?
The 3D intersection routines are not all finalized, some of them
in the AABB_tree package might end up being documented in the kernel
in some future release, once they are polished enough.
Currently, some of them are still mostly internal (aka, use at your
own risk :) ).
