[cgal-discuss] missing intersection detection for some combination of primitives ?
- To:
- Subject: [cgal-discuss] missing intersection detection for some combination of primitives ?
- Date: Tue, 08 Sep 2009 17:50:49 +0200
Hi,
first of all, I want to thank the developer behind the CGAL project for providing such a well-documented, open-source computational geometry library. We just started to use it in our mesh classes of our FEM library dolfin for providing some intersection detection and computation, and it is actually quite fun to work with.
Since we intend to use intersection quite heavily I have been wondering, why certain intersection test in 3D have not yet been implemented, such as the following
‘do_intersect(Point_3&, Point_3&)’
primitive_intersection_test.cpp:79: error: no matching function for call to ‘do_intersect(Point_3&, Segment_3&)’
primitive_intersection_test.cpp:81: error: no matching function for call to ‘do_intersect(Point_3&, Tetrahedron_3&)’
primitive_intersection_test.cpp:84: error: no matching function for call to ‘do_intersect(Segment_3&, Segment_3&)’
primitive_intersection_test.cpp:86: error: no matching function for call to ‘do_intersect(Segment_3&, Tetrahedron_3&)’
primitive_intersection_test.cpp:93: error: no matching function for call to ‘do_intersect(Tetrahedron_3&, Tetrahedron_3&)’
in particular the Point_3/another primitive are missing. Is there any special reason for that, a principle obstacle for implementing this correctly or do I just not use the right functions?
I just wonder, since for instance a Triangle_3 Tetrahedron_3 or Triangle_3 Triangle_3 intersection or intersection those objects with Bbox are implemented.
At a first glance at
http://www.cgal.org/Manual/beta/doc_html/cgal_manual/Kernel_23_ref/Function_do_intersect.html
opposed to the 3D case, the 2d case seems fairly complete.
Maybe you could give me some hints or pointers, how one might supply these additional tests?
Kind regards,
Andre
- [cgal-discuss] missing intersection detection for some combination of primitives ?, Andre Massing, 09/08/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Sylvain Pion, 09/08/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Andre Massing, 09/08/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Pierre Alliez, 09/10/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Andre Massing, 09/10/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Andre Massing, 09/09/2009
- Re: [cgal-discuss] missing intersection detection for some combination of primitives ?, Sylvain Pion, 09/09/2009
