- To:
- Subject: Re: [cgal-discuss] Deprecated include from boost::property_map
- Date: Tue, 22 Sep 2009 10:24:02 +0200
Hi Rob,
Thanks for your input. This warning will be fixed in the final release of
CGAL 3.5.
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
a écrit :
When compiling with recent versions of boost, the file
CGAL/boost/graph/properties.h line 24 causes a compiler warning. The
source of this warning is that boost/property_map.hpp is a deprecated
interface to the boost property_map, and should be replaced with
boost/property_map/property_map.hpp . This seems to resolve the
compiler warnings.
Cheers,
Rob
- [cgal-discuss] Deprecated include from boost::property_map, rob.patro, 09/17/2009
- Re: [cgal-discuss] Deprecated include from boost::property_map, Laurent Saboret, 09/22/2009
