- To:
- Subject: Re: [cgal-discuss] compiler is out of heap space
- Date: Thu, 24 Sep 2009 16:23:34 +0200
Sascha Räsch wrote:
Hi,Hi Sascha,
I'm using CGAL-3.5-beta1. My compiler (MSVC++ 2005) runs out of heap space if I compile the example
examples/Mesh_3/mesh_polyhedral_domain.cpp <http://www.cgal.org/Manual/beta/examples/Mesh_3/mesh_polyhedral_domain.cpp>
If I try instead to compile the code in the release mode, it succeeds
Thanks for any help in advance
Did you try to increase the heap size in the settings of your project ?
You may use /Zm option in additionnal command line parameters.
Regards,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] compiler is out of heap space, Sascha Räsch, 09/23/2009
- Re: [cgal-discuss] compiler is out of heap space, Stephane Tayeb, 09/24/2009
- Re: [cgal-discuss] compiler is out of heap space, Sascha Raesch, 09/25/2009
- Re: [cgal-discuss] compiler is out of heap space, Laurent Rineau (GeometryFactory), 09/25/2009
