- To:
- Subject: Re: [cgal-discuss] Triangulation 2D - remove_constraint
- Date: Thu, 24 Sep 2009 16:27:13 +0200
Lionel wrote:
Hello,
What does it mean when there is no answer to a question ?
It is stupid ? The answer is well documented ? Not all questions obtain an
answer ?
There is nothing to answer : it works like this ?
Thanks for your explanation,
Lionel
It means that it is an effort to look into your particular problem
and that nobody is currently willing or motivated to investigate
due to whatever: being busy with a customer, an article to finish,
research to pursue,....
andreas
- Re: Re: Re: [cgal-discuss] Triangulation 2D - remove_constraint, Lionel, 09/03/2009
- Re: Re: Re: Re: [cgal-discuss] Triangulation 2D - remove_constraint, Lionel, 09/24/2009
- Re: [cgal-discuss] Triangulation 2D - remove_constraint, Andreas Fabri, 09/24/2009
- Re: Re: [cgal-discuss] Triangulation 2D - remove_constraint, Lionel, 09/24/2009
- Re: [cgal-discuss] Triangulation 2D - remove_constraint, Laurent Rineau (GeometryFactory), 09/25/2009
