cgal-discuss - Re: [cgal-discuss] Triangulation 2D - remove_constraint
  • To:
  • Subject: Re: [cgal-discuss] Triangulation 2D - remove_constraint
  • Date: Fri, 25 Sep 2009 13:28:32 +0200
Le jeudi 24 septembre 2009 16:16:15, Lionel a écrit :
> Hello,
> What does it mean when there is no answer to a question ?
> It is stupid ? The answer is well documented ? Not all questions obtain an
> answer ?
> There is nothing to answer : it works like this ?
If you want to maximize your chance to get help, please give us more
informations. You should read the following:
http://www.cgal.org/bug_report.html
You should try to create a small .cpp file, that shows your problem, and that
can be easily compiled on everyone's machine. That way, it will remove any
possible ambiguity in your problem, and people will have a concrete problem
to
have a look on.
Best regards,
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
