- To:
- Subject: Re: [cgal-discuss] "and will not be compiled"
- Date: Fri, 25 Sep 2009 17:11:59 +0200
>Le vendredi 25 septembre 2009 16:51:10, Marcos R. P. a écrit :
> Hello!
> Somebody can help me to solve the problem bellow?
> Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
> OpenGL include:
> OpenGL libraries: glu32;opengl32
> NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will
> not be activated. CGAL_Qt3 needs Qt3, cannot be configured.
> USING QT4_VERSION = '4.5.2'
> OpenGL include:
> OpenGL definitions:
> Qt4 include: C:/Qt/2009.03/qt/include
> Qt4 libraries:
> optimized;C:/Qt/2009.03/qt/lib/qtmain.lib;debug;C:/Qt/2009.03/qt/lib/qtmai
> nd.lib;optimized;C:/Qt/2009.03/qt/lib/QtOpenGL4.lib;debug;C:/Qt/2009.03/qt/
> lib/QtOpenGLd4.lib;opengl32.lib glu32.lib gdi32.lib
> user32.lib;optimized;C:/Qt/2009.03/qt/lib/QtGui4.lib;debug;C:/Qt/2009.03/q
> t/lib/QtGuid4.lib;imm32;winmm;optimized;C:/Qt/2009.03/qt/lib/QtCore4.lib;de
> bug;C:/Qt/2009.03/qt/lib/QtCored4.lib;ws2_32 Qt4 definitions: -DQT_DLL
> moc executable: C:/Qt/2009.03/qt/bin/moc.exe
> uic executable: C:/Qt/2009.03/qt/bin/uic.exe
> Configuring C:/CGAL-3.5-beta1/demo/Voronoi_diagram_2 demo
> NOTICE: This demo requires CGAL and Qt3, and will not be compliled
> Configuring C:/CGAL-3.5-beta1/demo/Stream_lines_2 demo
> NOTICE: This demo requires CGAL, Qt3, and OpenGL, and will not be compiled.
> Configuring C:/CGAL-3.5-beta1/demo/Robustness demo
> NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
> Configuring C:/CGAL-3.5-beta1/demo/Segment_Delaunay_graph_2 demo
> NOTICE: This demo requires CGAL,, Core, and Qt3, and will not be compiled.
> Configuring C:/CGAL-3.5-beta1/demo/Snap_rounding_2 demo
> Configuring C:/CGAL-3.5-beta1/demo/Spatial_searching demo
> Configuring C:/CGAL-3.5-beta1/demo/Straight_skeleton_2 demo
> Configuring C:/CGAL-3.5-beta1/demo/Surface_mesher demo
> I have a C:\Zlib with zlib1,dll, C:\Zlib\include, C:\Zlib\lib, C:\Zlib\test
> and I tried ADD ENTRY in cmake-gui: ZLIB_INCLUDE_DIR and ZLIB_LIBRARY, but
> the same message appears.
ZLIB_INCLUDE_DIR must be equal to "C:\Zlib\include".
As for ZLIB_LIBRARY, it must be full path to zlib.lib that corresponds to
zlib1.dll, probably "C:\Zlib\zlib.lib". You must also have C:\Zlib on the
PATH
environment variable, so that zlib1.dll can be found at runtime by the DLL
loader.
Anyway, adding zlib will only permit to build CGAL_ImageIO with the ZLIB
support. All the other messages are about Qt3.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] "and will not be compiled", Marcos R. P., 09/25/2009
- Re: [cgal-discuss] "and will not be compiled", Laurent Rineau (GeometryFactory), 09/25/2009
- Res: [cgal-discuss] "and will not be compiled", Marcos R. P., 09/25/2009
- Re: Res: [cgal-discuss] "and will not be compiled", Laurent Rineau (GeometryFactory), 09/25/2009
