cgal-discuss - Res: [cgal-discuss] "and will not be compiled"
  • To:
  • Subject: Res: [cgal-discuss] "and will not be compiled"
  • Date: Fri, 25 Sep 2009 10:09:09 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=N9cYY5fNkqBIFZA/m6DSOZS+hKKhqcEwfog/vxO9a3devxb+8MluizUbosksUIglWzt4iwiTGamvA+kfZmIRg4xZEYRwCTaTXADDCTTA//jlSA6k9y5LgDYDvK/iWWQF2nYuWWOQRMC4+06wB0YRPSWMTNHaZnoHL/917I5X9+0=;
Thanks, dr. Rineau.
The Zlib was found.
Now the following message persist:
"NOTICE: This demo requires CGAL and Qt3, and will not be compiled."
How could I compile the demos after the cmake-gui since the QT seems correctly installed?
Marcos.
De: Laurent Rineau (GeometryFactory) <>
Para:
Enviadas: Sexta-feira, 25 de Setembro de 2009 12:11:59
Assunto: Re: [cgal-discuss] "and will not be compiled"
>Le vendredi 25 septembre 2009 16:51:10, Marcos R. P. a écrit :
> Hello!
> Somebody can help me to solve the problem bellow?
> Could NOT find ZLIB  (missing:  ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
> OpenGL include:
> OpenGL libraries:  glu32;opengl32
> NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will
>  not be activated. CGAL_Qt3 needs Qt3, cannot be configured.
> USING QT4_VERSION = '4.5.2'
> OpenGL include:
> OpenGL definitions:
> Qt4 include:        C:/Qt/2009.03/qt/include
> Qt4 libraries:
>  optimized;C:/Qt/2009.03/qt/lib/qtmain.lib;debug;C:/Qt/2009.03/qt/lib/qtmai
> nd.lib;optimized;C:/Qt/2009.03/qt/lib/QtOpenGL4.lib;debug;C:/Qt/2009.03/qt/
> lib/QtOpenGLd4.lib;opengl32.lib glu32.lib gdi32.lib
>  user32.lib;optimized;C:/Qt/2009.03/qt/lib/QtGui4.lib;debug;C:/Qt/2009.03/q
> t/lib/QtGuid4.lib;imm32;winmm;optimized;C:/Qt/2009.03/qt/lib/QtCore4.lib;de
> bug;C:/Qt/2009.03/qt/lib/QtCored4.lib;ws2_32 Qt4 definitions:    -DQT_DLL
> moc executable:    C:/Qt/2009.03/qt/bin/moc.exe
> uic executable:    C:/Qt/2009.03/qt/bin/uic.exe
> Configuring  C:/CGAL-3.5-beta1/demo/Voronoi_diagram_2 demo
> NOTICE: This demo requires CGAL and Qt3, and will not be compliled
> Configuring  C:/CGAL-3.5-beta1/demo/Stream_lines_2 demo
> NOTICE: This demo requires CGAL, Qt3, and OpenGL, and will not be compiled.
> Configuring  C:/CGAL-3.5-beta1/demo/Robustness demo
> Configuring  C:/CGAL-3.5-beta1/demo/Segment_Delaunay_graph_2 demo
> NOTICE: This demo requires CGAL,, Core, and Qt3, and will not be compiled.
> Configuring  C:/CGAL-3.5-beta1/demo/Snap_rounding_2 demo
> Configuring  C:/CGAL-3.5-beta1/demo/Spatial_searching demo
> Configuring  C:/CGAL-3.5-beta1/demo/Straight_skeleton_2 demo
> Configuring  C:/CGAL-3.5-beta1/demo/Surface_mesher demo
> I have a C:\Zlib with zlib1,dll, C:\Zlib\include, C:\Zlib\lib, C:\Zlib\test
>  and I tried ADD ENTRY in cmake-gui: ZLIB_INCLUDE_DIR and ZLIB_LIBRARY, but
>  the same message appears.
ZLIB_INCLUDE_DIR must be equal to "C:\Zlib\include".
As for ZLIB_LIBRARY, it must be full path to zlib.lib that corresponds to
zlib1.dll, probably "C:\Zlib\zlib.lib". You must also have C:\Zlib on the PATH
environment variable, so that zlib1.dll can be found at runtime by the DLL
loader.
Anyway, adding zlib will only permit to build CGAL_ImageIO with the ZLIB
support. All the other messages are about Qt3.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
