- To:
- Subject: [cgal-discuss] is_at_open_boundary() problem
- Date: Sat, 26 Sep 2009 00:27:03 +0200 (CEST)
I'm trying to compile this line:
if(e.target().is_at_infinity()) x = e.target().point().x()-1;
and get this error:
CGAL::I_Filtered_iterator<CGAL::CGALi::In_place_list_iterator<CGAL::Arr_vertex<CGAL::Arr_vertex_base<CGAL::Point_2<CGAL::Simple_cartesian<double>
CGAL::Arr_halfedge_base<CGAL::Arr_linear_object_2<CGAL::Simple_cartesian<double>
> >, CGAL::Arr_face_base>,
std::allocator<CGAL::Arr_vertex<CGAL::Arr_vertex_base<CGAL::Point_2<CGAL::Simple_cartesian<double>
> >, CGAL::Arr_face_base> > >,
CGAL::Arrangement_on_surface_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
CGAL::Arr_unb_planar_topology_traits_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
CGAL::Arr_default_dcel<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
> > > >::_Is_concrete_vertex,
> > > >::Vertex, int, std::bidirectional_iterator_tag>’ has no member named
‘is_at_infinity’
I read that this method has been replaced by is_at_open_boundary(), but I've
not found a way to write the equivalent statement without get some kind of
error. How can I solve it?
Thanks in advance. Best regards.
- [cgal-discuss] is_at_open_boundary() problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] is_at_open_boundary() problem, Eric Berberich, 09/26/2009
- Re: [cgal-discuss] is_at_open_boundary() problem, Marco Aurelio Sterpa, 09/26/2009
