- To:
- Subject: Re: [cgal-discuss] is_at_open_boundary() problem
- Date: Sat, 26 Sep 2009 11:50:58 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=WMbe1RDhh745vInNkgZ1JV61oJZ3TRpIXOXHH4XnjLQday8MaYHt4HDvixk891+WnX RkO45vVBk2CxKdfurXv6fe9e4gZPijcm9ZBYRSYitA3WvQH/Vg2Q6GkDIHDPH3iKejL/ RVd/EA0+4zBuOu3+LOhAu3YvdezKjHSa1Y7Nw=
I'm sorry to get wrong with that, the right statement is if(!e.target()....); with this said, I get a static error at compile time. I've also tried with e.curve() but I got the same problem, it seems to be just like I'm using a wrong type (Vertex). Thanks in advance.
Best regards.
2009/9/26 Eric Berberich <>
Sterpa wrote:
I'm trying to compile this line:
if(e.target().is_at_infinity()) x = e.target().point().x()-1;
and get this error:
CGAL::I_Filtered_iterator<CGAL::CGALi::In_place_list_iterator<CGAL::Arr_vertex<CGAL::Arr_vertex_base<CGAL::Point_2<CGAL::Simple_cartesian<double>
CGAL::Arr_halfedge_base<CGAL::Arr_linear_object_2<CGAL::Simple_cartesian<double>,
std::allocator<CGAL::Arr_vertex<CGAL::Arr_vertex_base<CGAL::Point_2<CGAL::Simple_cartesian<double>, CGAL::Arr_face_base>,
CGAL::Arrangement_on_surface_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>, CGAL::Arr_face_base> > >,
,CGAL::Arr_unb_planar_topology_traits_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
,CGAL::Arr_default_dcel<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>
CGAL::Arrangement_on_surface_2<CGAL::Arr_linear_traits_2<CGAL::Simple_cartesian<double>::_Is_concrete_vertex,
‘is_at_infinity’::Vertex, int, std::bidirectional_iterator_tag>’ has no member named
I read that this method has been replaced by is_at_open_boundary(), but I've
not found a way to write the equivalent statement without get some kind of
error. How can I solve it?
Thanks in advance. Best regards.--
Hi,
you mean a runtime error?
The point is:
if (e.target().is_at_open_boundary())
should do the job, but
x = e.target().point().x() - 1;
if e.target() is at an open boundary, it's not possible to access a point there (as there is none). In case open boundary is infinity in x-direction, I also doubt what "oo - 1" is. In case you consider a vertical asymptote check whether you can access that x-information from e.curve().
eriC
- [cgal-discuss] is_at_open_boundary() problem, Sterpa, 09/26/2009
- Re: [cgal-discuss] is_at_open_boundary() problem, Eric Berberich, 09/26/2009
- Re: [cgal-discuss] is_at_open_boundary() problem, Marco Aurelio Sterpa, 09/26/2009
