- To:
- Subject: Re: [cgal-discuss] extracts from polyhedron and reinsertion
- Date: Wed, 30 Sep 2009 00:42:15 +0200
Le mardi 29 septembre 2009 12:15:15,
a écrit :
> Good afternoon,
> We use CGAL library and self-learn with CGAL on-line manual and tutorials.
> We succeeded in putting parts together rather easily but there are another
> two problems we don’t know how to solve.
> -1-
> Our working mesh is a mesh with nearly 180000 facets but the area we’re
> interested in is a little part of this mesh (1/15). On the little area
> we’re using polyhedra, nefpolyhedra and boolean operations on
> nefpolyhedra. What is the right and safer method to work on extracts of a
> mesh and reinsert them in the entire mesh? From the polyhedron made of our
> big mesh we succeeded in building another polyhedron made of our little
> mesh but we didn’t use Cgal primitives. Which primitives are to be used in
> order to split the polyhedron into two polyhedrons and reinsert the little
> polyhedron in the big one?
If the Euler operations cannot be used, you can build a polyhedron using the
incremental builder. Maybe you can "make a hole" in your big polyhedron, and
fill the hole using incremental builder carefully.
Without more information from your side, I doubt somebody can give you a
better advice.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] extracts from polyhedron and reinsertion, pascale.bergeret, 09/29/2009
- Re: [cgal-discuss] extracts from polyhedron and reinsertion, Laurent Rineau (GeometryFactory), 09/30/2009
