- To:
- Subject: Re: [cgal-discuss] B-A on nefpolyhedrons sometimes fails
- Date: Wed, 30 Sep 2009 00:44:44 +0200
Le mardi 29 septembre 2009 12:17:38,
a écrit :
> Good afternoon,
> We use CGAL library and self-learn with CGAL on-line manual and tutorials.
> We succeeded in putting parts together rather easily but there are another
> two problems we don’t know how to solve.
> -2-
> We encounter some difficulties when trying to calculate B-A where B and A
> are both Nef-polyhedrons (B with nearly 70000 facets). The process works
> well on many actual cases but fails sometimes. Could you give us some
> hints to understand which problem is behind?
> Thank you for your help.
Well, as least you should give more information of that failure. Is that a
segmentation? An uncatched exception? An assertion? An arithmetic error? A
memory or CPU exhaustion? Anything else? I am sure you can tell us more, and
show us, for example, the error log.
You can see hints here on all the informations you could give us:
http://www.cgal.org/bug_report.html
Laurent Rineau, PhD
Release Manager of the CGAL Project
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] B-A on nefpolyhedrons sometimes fails, pascale.bergeret, 09/29/2009
- Re: [cgal-discuss] B-A on nefpolyhedrons sometimes fails, Laurent Rineau (GeometryFactory), 09/30/2009
