- To:
- Subject: [cgal-discuss] failed intersection detection in AABB tree
- Date: Mon, 12 Oct 2009 15:12:35 +0200
Hi all,
I discovered a slightly strange behavior when using the AABB tree. It does not discover the right number of intersections between a list of triangles (3) and a given test triangle (3 intersections only at one vertex) *although* the use of the pure CGAL::do_intersect function detects the intersection correctly. It seems to me (only a vague guess) that the foregoing bounding box intersection for finding good candidates computes some false negatives and throws two actual intersections cases away.
The attached code illustrates the example.
Greetings,
Andre
#include <CGAL/AABB_triangle_primitive.h> #include <CGAL/AABB_tree.h> // *Must* be inserted before kernel! #include <CGAL/AABB_traits.h> #include <CGAL/AABB_triangle_primitive.h> #include <CGAL/Bbox_3.h> #include <CGAL/Simple_cartesian.h> //used kernel typedef CGAL::Simple_cartesian<double> K; ///Definition of the used geometric primitives types. typedef K::Point_3 Point_3; typedef K::Segment_3 Segment_3; typedef K::Triangle_3 Triangle_3; typedef K::Tetrahedron_3 Tetrahedron_3; typedef K::Iso_cuboid_3 Iso_cuboid_3; typedef K::Ray_3 Ray_3; typedef K::Line_3 Line_3; typedef CGAL::Bbox_3 Bbox_3; typedef std::vector<Triangle_3> Triangles; typedef Triangles::iterator Tri_Iterator; typedef CGAL::AABB_triangle_primitive<K,Tri_Iterator> CellPrimitive; typedef CGAL::AABB_traits<K, CellPrimitive> AABB_triangle_traits; typedef CGAL::AABB_tree<AABB_triangle_traits> Tree; typedef Tree::Primitive_id Primitive_id; int main() { double frac = 1.0/3.0; Point_3 e0(0.0,0.0,0.0); Point_3 a(frac, frac, 0.0); Point_3 b(0.0, frac, 0.0); Point_3 c(frac, 2*frac, 0.0); Point_3 d(0.0, 2*frac, 0.0); Point_3 x(-1.0, 0.0, 0.0); Point_3 y(-1.0, 1.0, 0.0); Triangles triangles; triangles.push_back(Triangle_3(e0,a,b)); triangles.push_back(Triangle_3(b,a,c)); triangles.push_back(Triangle_3(b,c,d)); Triangle_3 test_tri(b,x,y); std::cout <<"Intersection detection via CGAL::do_intersect:" << std::endl; int trij = 0; int counter = 0; for (Tri_Iterator i = triangles.begin(); i != triangles.end(); ++i) { ++trij; if (CGAL::do_intersect(test_tri,*i)) { std::cout <<"Test triangle intersects with triangle " << trij <<std::endl; ++counter; } else std::cout <<"DOES NOT intersect with triangle " << trij <<std::endl; } std::cout <<"------------------------------" <<std::endl; std::cout <<counter << " intersection(s) found." <<std::endl; //Now intersection using CGAL AABB_tree Tree tree(triangles.begin(), triangles.end()); std::cout << std::endl <<"Intersection detection using AABB tree" << std::endl; std::list<Primitive_id> primitives; tree.all_intersected_primitives(test_tri, std::back_inserter(primitives)); for (std::list<Primitive_id>::const_iterator i = primitives.begin(); i != primitives.end(); ++i) std::cout <<"Test triangle intersects with triangle " << (*i - triangles.begin()) << std::endl; std::cout <<"------------------------------" <<std::endl; std::cout << tree.number_of_intersected_primitives(test_tri) << " intersection(s) found." << std::endl; return 0; }
- [cgal-discuss] failed intersection detection in AABB tree, Andre Massing, 10/12/2009
- Re: [cgal-discuss] failed intersection detection in AABB tree, Andre Massing, 10/13/2009
- Re: [cgal-discuss] failed intersection detection in AABB tree, Camille Wormser, 10/13/2009
