- To:
- Subject: Re: [cgal-discuss] failed intersection detection in AABB tree
- Date: Tue, 13 Oct 2009 11:02:33 +0200
Hi again,
Andre Massing wrote:
Hi all,
I discovered a slightly strange behavior when using the AABB tree. It does not discover the right number of intersections between a list of triangles (3) and a given test triangle (3 intersections only at one vertex) *although* the use of the pure CGAL::do_intersect function detects the intersection correctly. It seems to me (only a vague guess) that the foregoing bounding box intersection for finding good candidates computes some false negatives and throws two actual intersections cases away.
The attached code illustrates the example.
I just wanted to ask, whether the aforementioned described behavior is a bug in the AABB tree? Or is there anything else I have to take into account or can do about?
Greetings,
Andre
- [cgal-discuss] failed intersection detection in AABB tree, Andre Massing, 10/12/2009
- Re: [cgal-discuss] failed intersection detection in AABB tree, Andre Massing, 10/13/2009
- Re: [cgal-discuss] failed intersection detection in AABB tree, Camille Wormser, 10/13/2009
