- To:
- Subject: Re: [cgal-discuss] offset
- Date: Tue, 13 Oct 2009 14:34:18 +0200
Hi Issha,
Issha Kayo wrote:
[...]As you have noted, vertices always store their representative in the
Assume a point at (0.01 0.5 0.5) might be in a cell, one of whose
vertices is out of the original cube. In this case I expect
point(Periodic_point) to return the position of the vertex, say, (-0.05,
0.5, 0.5). The actual return, however, seems to be (0.95, 0.5, 0.5).
original cube. In the case a cell "wraps around" its representation is
transposed in positive x-, y-, z-direction, respectively. That is, in
your case we do not transpose
(0.95, 0.5, 0.5) to (-0.05, 0.5, 0.5) (*)
but rather
(0.01, 0.5, 0.5) to (1.01, 0.5,0.5)
That choice is somewhat arbitrary, but it was necessary to define a
consistent behavior.
If you really need the output to behave like in (*) you could iterate
through all four periodic_points of a cell and subtract 1 from the
offset (second entry) of each vertex in each direction the cell wraps
around (example below). Beware that this works only if you are computing
in 1-sheeted covering space.
hope this helps
Manuel
Example:
// Additionally required typedefs
typedef PDT::Periodic_point Periodic_point;
typedef PDT::Offset Offset;
// Extract the Periodic_points from the data structure
Periodic_point pp[4];
for (int i=0 ; i<4 ; i++) {
pp[i] = T.periodic_point(c,i);
// Figure out in which directions the cell wraps around
int off[3];
for (int d=0 ; d<3 ; d++) {
bool does_wrap=false;
does_wrap = does_wrap || (pp[i].second[d]!=0);
off[d] = (does_wrap ? -1 : 0);
// wrap_offset contains the required translation
Offset wrap_offset(off[0],off[1],off[2]);
// Apply the translation in wrap_offset to the Periodic_points
pp[i] = std::make_pair(pp[i].first, pp[i].second + wrap_offset);
std::cout<< T.point(pp[i])<<std::endl;
As an example, please see the following code. I can easily imagine I'm
doing something very silly ....
Thank you,
Issha
#include <CGAL/Periodic_3_triangulation_traits_3.h>
#include <CGAL/Periodic_3_Delaunay_triangulation_3.h>
#include <iostream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Periodic_3_triangulation_traits_3<K> GT;
typedef CGAL::Periodic_3_Delaunay_triangulation_3<GT> PDT;
typedef PDT::Point Point;
int main()
PDT T;
// Input point grid (27 points)
for (double x=0.1 ; x < .9 ; x += 0.33) {
for (double y=0.1 ; y < .9 ; y += 0.33) {
for (double z=0.1 ; z < .9 ; z += 0.33) {
T.insert(Point(x,y,z));
Point p(0.05, 0.5, 0.5);
PDT::Cell_handle c;
c=T.locate(p);
T.convert_to_1_sheeted_covering();
std::cout << T.point(T.periodic_point(c,0)) << std::endl;
std::cout << T.point(T.periodic_point(c,1)) << std::endl;
std::cout << T.point(T.periodic_point(c,2)) << std::endl;
std::cout << T.point(T.periodic_point(c,3)) << std::endl;
return 0;
The resulting output is
1.1 0.43 0.43 <--- If 0.1 0.43 0.43, I'm happy.
1.1 0.76 0.43 <--- If 0.1 0.76 0.43, I'm happ..
0.76 0.76 0.76 <--- If -0.24 0.76 0.76, I'm hap...
1.1 0.43 0.76 <--- If 0.1 0.43 0.76, ..
- [cgal-discuss] offset, Issha Kayo, 10/10/2009
- Re: [cgal-discuss] offset, Manuel Caroli, 10/11/2009
- Re: [cgal-discuss] offset, Issha Kayo, 10/12/2009
- Re: [cgal-discuss] offset, Manuel Caroli, 10/13/2009
- Re: [cgal-discuss] offset, Issha Kayo, 10/13/2009
