cgal-discuss - [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others)
  • To:
  • Subject: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others)
  • Date: Tue, 13 Oct 2009 19:20:09 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=d4meP21paOBlhAs5DisoqvdmCLf0O+WQfXfcB71IHnH2ooSxwAlPXsYumyOWBaeocDFba1rhKINSA3r+PQ3RGTaCXAZo7V+rbj+lel/XR1gfqhOgDrPC7AA4WIS1hU+Lw3rAX1XSprNhqsLexwZJPYkHl/aS0Yc2wy6NnRD3fiQ=;
I'm sorry, I'm a noob and have two questions.  I seem to have run into the notorious "Could NOT find ZLIB  (missing:  ZLIB_LIBRARY ZLIB_INCLUDE_DIR)" configuration alert.  I'm confused as to how to go about setting up ZLIB so that CMake sees it.
What are ZLIB_LIBRARY and ZLIB_INCLUDE_DIR?  Are they environment variables?  (I'm running Visual C++ 2008 Express edition on Windows 7.)  Are they constants inside a CMake file, or inside a CGAL file?
Laurent Rineau,has generously answered a prior poster that...
"ZLIB_INCLUDE_DIR must be equal to 'C:\Zlib\include'.
"As for ZLIB_LIBRARY, it must be full path to zlib.lib that corresponds to
zlib1.dll, probably "C:\Zlib\zlib.lib". You must also have C:\Zlib on the PATH
, so that zlib1.dll can be found at runtime by the DLL
loader."
(I do have C:\Zlib on the PATH environment variable.  But I have no idea what he means by "ZLIB_INCLUDE_DIR must be equal to 'C:\Zlib\include'."  Equal to that string...where?  In what file is this written?)
My second question, if I want only to build a Demo of "Alpha_shapes_2," which of the following CMake line items need to be checked in their checkboxes?  (I'm guessing WITH_examples doesn't need a check.  What about the others?)
WITH_CGAL_Core
WITH_CGAL_ImageIO
WITH_CGAL_PDB
WITH_CGAL_Qt3
WITH_CGAL_Qt4
WITH_CPACK
WITH_GMP
WITH_LEDA
WITH_demos
WITH_examples
Thanks for any help.
