Re: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others)
- To:
- Subject: Re: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others)
- Date: Fri, 16 Oct 2009 00:13:29 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=mEyY1IlVwTUWFktl6uii1GWS3ah+mHCrZbVed60fDOYVh6F/ebb3Q8Z1S4sxvuNmhr pYLavXf5Z6G/RPQPDds5fc+SOt/itfUYzKC+t/JopmtjNKigJBvcWUoanVdt5e6EzezU 2tk4Tpl8wA6fZt3j/A459XnNr6z/ADr7oGPSI=
HI, all:
I think I have successfully install CGAL-3.5, since I can run the demo/Triangulation_2 without any problem! But when I tried to compile the Alapha_shpae_2 or Nef_3 demos, both doesn't work at all. I even cannot find the source files in the *.sln file, I only can see the BUILD ALL and ZERO_CHECK when I opened it with MSVS2008. Could anyone help me figure it out?
One possible reason I am thinking is that I don't install the QT3, but I cannot find the QT3 code anywhere from webiste, could anyone give me a link?
Thanks a lot!
Guang
- [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others), A S, 10/14/2009
- Re: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others), Laurent Rineau (GeometryFactory), 10/14/2009
- Re: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others), Laurent Rineau (GeometryFactory), 10/16/2009
- Re: [cgal-discuss] Configuration of CMake to produce only one particular Demo (I don't care about any others), Zheng,Guang, 10/16/2009
