cgal-discuss - Re: [cgal-discuss] How to navigate Outputiterator for inicident_edges?
  • To:
  • Subject: Re: [cgal-discuss] How to navigate Outputiterator for inicident_edges?
  • Date: Wed, 14 Oct 2009 18:21:39 +0200
Hi Suejung,
for instance you could use do it in the following way:
std::vector<Cell_handle> cell_vector;
t.finite_incident_cells(v, std::back_inserter(cell_vector));
Now you find all the finite cells that contain v as one of their vertices in the std::vector cell_vector.
Best
Manuel
Suejung B. Huh wrote:
Thanks, Manuel,
But does anyone have an example code to use "OutputIterator"?
I am not sure how to use
t.finite_incident_cells ( Vertex_handle v, OutputIterator cells)
without ending condition.
Thanks in advance,
-s
On Fri, Oct 9, 2009 at 1:43 AM, Manuel Caroli < <mailto:>> wrote:
Dear Suejung,
<mailto:>
wrote:
int main()
Delaunay T;
std::ifstream in("data/voronoi.cin");
Point p;
while(in >> p){
T.insert(p);
cout << "All Cells ----------------------------\n";
Cell_iterator cit =T.cells_begin();
for ( ; cit !=T.cells_end(); ++cit) {
if (! T.is_infinite(cit)) continue;
note that there is a Finite_cells_iterator that does this automatically
// T.incident_edges(cit) ?????? <<--- Want to find edges!!!
I am not sure to understand what you want to do. What do you mean by
edges incident to a cell? These are the edges of the cell that you
can extract immediately. There is a function incident_edges that
gives you the edges incident to a *vertex*. In this case you have to
provide it with an output iterator as second argument.
To understand the internal representation of a triangulation please
read chapter 35.1 of the user manual (of CGAL 3.6):
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
For the available access functions see the reference documentation:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
hope this helps
Manuel
return 0;
-- You are currently subscribed to cgal-discuss.
