cgal-discuss - Re: [cgal-discuss] How to navigate Outputiterator for inicident_edges?
  • To:
  • Subject: Re: [cgal-discuss] How to navigate Outputiterator for inicident_edges?
  • Date: Wed, 14 Oct 2009 14:47:21 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:reply-to:in-reply-to:references:date:message-id :subject:from:to:content-type; b=HVylJirc79s/VwD8/53/Rhu234plTc9XOz/srshu3a5NGcz8nxwPEYCBrFVKfFpb9t gcWdyUgoYaPckgoepGRrkm4yiCVijRXhvLLwt2v2wm9axIqeTAP/6BncaJW5TVcaIeE/ BS4GLt0U4VyaqKh88gWDZLMU0lpvGKmBqcqLw=
Much Thanks, Andreas and Manuel,
Given a facet and a cell, what should I do to figure out the cell has the facet?
Also what is the usagae of Cell handle c here?
t.incident_cells ( Cell_handle c, int i, int j)
-s
On Wed, Oct 14, 2009 at 11:22 AM, Andreas Fabri <> wrote:
Hello Suejung,
this is covered in the Hello World programs in
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Introduction/Chapter_main.html
best regards,
andreas
Suejung B. Huh wrote:
Thanks, Manuel,
But does anyone have an example code to use "OutputIterator"?
I am not sure how to use
t.finite_incident_cells ( Vertex_handle v, OutputIterator cells)
without ending condition.
Thanks in advance,
-s
On Fri, Oct 9, 2009 at 1:43 AM, Manuel Caroli < <mailto:>> wrote:
   Dear Suejung,
    <mailto:> wrote:
       int main()
        Delaunay T;
        std::ifstream in("data/voronoi.cin");
        Point p;
        while(in >> p){
          T.insert(p);
        cout << "All Cells ----------------------------\n";
        Cell_iterator cit =T.cells_begin();
        for ( ; cit !=T.cells_end(); ++cit) {
          if (! T.is_infinite(cit)) continue;
   note that there is a Finite_cells_iterator that does this automatically
          //  T.incident_edges(cit) ?????? <<--- Want to find edges!!!
   I am not sure to understand what you want to do. What do you mean by
   edges incident to a cell? These are the edges of the cell that you
   can extract immediately. There is a function incident_edges that
   gives you the edges incident to a *vertex*. In this case you have to
   provide it with an output iterator as second argument.
   To understand the internal representation of a triangulation please
   read chapter 35.1 of the user manual (of CGAL 3.6):
   http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html
   For the available access functions see the reference documentation:
   http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html
   hope this helps
   Manuel
        return 0;
   --    You are currently subscribed to cgal-discuss.
