- To:
- Subject: [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3
- Date: Fri, 16 Oct 2009 02:24:19 -0700 (PDT)
Hi,
I am using CGAL in order to make boolean operations on 3D mesh and I would
like to use CGAL Polyhedrons to do that (according to SIGGRAPH 2008 course,
slide #63 to be more specific).
My code is :
#include "CGAL/Cartesian.h"
#include "CGal/Polyhedron_3.h"
#include "CGal/Nef_Polyhedron_3.h"
#include "CGal/IO/Polyhedron_iostream.h"
typedef CGAL::Cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef;
class MyClass
public:
static Nef* create_nef ();
Nef* MyClass::create_nef ()
Polyhedron p;
return new Nef (p);
I got these compilation errors with MS Visual Studio 2008 :
Erreur 63 error C2039: 'lo' : n'est pas membre de
'CGAL::Box_intersection_d::Box_d<NT_,N>'
cgal\include\cgal\nef_3\bounding_box_3.h 89
Erreur 64 error C2065: 'lo' : identificateur non déclaré
Erreur 65 error C2039: 'hi' : n'est pas membre de
cgal\include\cgal\nef_3\bounding_box_3.h 90
Erreur 66 error C2065: 'hi' : identificateur non déclaré
I inspected the cgal/box_intersection/box_d.h file and in fact, one Box_d
class has those two attributes, but not the other ones. I think that the
class choice, made with template parameters is wrong.
Has anyone ever got that problem and know how to fix that issue ?
View this message in context:
http://www.nabble.com/Compilation-error-in-boundig_box_3.h-when-using-Polyhedron_3-tp25921691p25921691.html
- [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3, shenga, 10/16/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3, shenga, 10/19/2009
