Re: [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3
- To:
- Subject: Re: [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3
- Date: Mon, 19 Oct 2009 00:32:18 -0700 (PDT)
No one got an idea ?
shenga wrote:
> Hi,
> I am using CGAL in order to make boolean operations on 3D mesh and I would
> like to use CGAL Polyhedrons to do that (according to SIGGRAPH 2008
> course, slide #63 to be more specific).
> My code is :
> #include "CGAL/Cartesian.h"
> #include "CGal/Polyhedron_3.h"
> #include "CGal/Nef_Polyhedron_3.h"
> #include "CGal/IO/Polyhedron_iostream.h"
> typedef CGAL::Cartesian<double> Kernel;
> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
> typedef CGAL::Nef_polyhedron_3<Kernel> Nef;
> class MyClass
> public:
> static Nef* create_nef ();
> Nef* MyClass::create_nef ()
> Polyhedron p;
> return new Nef (p);
> I got these compilation errors with MS Visual Studio 2008 :
> Erreur 63 error C2039: 'lo' : n'est pas membre de
> 'CGAL::Box_intersection_d::Box_d<NT_,N>'
> cgal\include\cgal\nef_3\bounding_box_3.h 89
> Erreur 64 error C2065: 'lo' : identificateur non déclaré
> Erreur 65 error C2039: 'hi' : n'est pas membre de
> cgal\include\cgal\nef_3\bounding_box_3.h 90
> Erreur 66 error C2065: 'hi' : identificateur non déclaré
> I inspected the cgal/box_intersection/box_d.h file and in fact, one Box_d
> class has those two attributes, but not the other ones. I think that the
> class choice, made with template parameters is wrong.
> Has anyone ever got that problem and know how to fix that issue ?
View this message in context:
http://www.nabble.com/Compilation-error-in-boundig_box_3.h-when-using-Polyhedron_3-tp25921691p25954202.html
- [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3, shenga, 10/16/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] Compilation error in boundig_box_3.h when using Polyhedron_3, shenga, 10/19/2009
