- To:
- Subject: Re: [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:
- Date: Sun, 18 Oct 2009 10:11:11 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=dQVaKmCWLr2IpGp1RYTg0KwvossBUGtFrmi54BIsyN/lRKZrEczWNTMcl5pRK7E/iBlEMMBxNVfhwlEaoVFqHkloWge5bipUpxm2tj7gRqp2Qu0xXT2Nu3VSQTx+CmUeNFepv+QgIsvTy6sWe10Zsg/6BlHkMAJ/gju45lfJ8oU=;
Thank you for this info. I'll probably have more questions (i.e., If, by "...modify also the source directory," you're referring to the large upper pane, where do I modify the source directory in that?).
(As opposed to the little field at the top of the window)? I know only of the "Where is the source code:" field at the top of the window. Is that the same source that you're talking about?)
Thanks again.
--- On Sun, 10/18/09, Laurent Rineau (GeometryFactory) <> wrote:
- [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:, A S, 10/18/2009
- Re: [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:, Laurent Rineau (GeometryFactory), 10/18/2009
- Re: [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:, A S, 10/18/2009
