cgal-discuss - Re: [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:
  • To:
  • Subject: Re: [cgal-discuss] ZLIB, CGAL, CMake--I'm making some progress here:
  • Date: Sun, 18 Oct 2009 19:24:19 +0200
Le dimanche 18 octobre 2009 19:11:11, A S a écrit :
> Thank you for this info. I'll probably have more questions (i.e., If, by
> "...modify also the source directory," you're referring to the large upper
> pane, where do I modify the source directory in that?).
> (As opposed to the little field at the top of the window)? I know only
> of the "Where is the source code:" field at the top of the window. Is
> that the same source that you're talking about?)
> Thanks again.
Sorry, I was not clear when I said "in that pane", in my previous message.
What I call the "CMake GUI" is the Qt graphical interface that is launched
with the program cmake-gui.exe. At the top of that window, just below the
menus, you can see and change the source directory and the binaries directory.
Laurent Rineau, PhD
Release Manager of the CGAL Project
http://www.cgal.org/
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
