cgal-discuss - [cgal-discuss] point compare problem [update_exact()]
  • To:
  • Subject: [cgal-discuss] point compare problem [update_exact()]
  • Date: Tue, 20 Oct 2009 07:32:40 +0200 (CEST)
I'm using CGAL 3.5 on Ubuntu 8.10. This is the code of a my data structure:
class Node {
private:
Point_2 v_ij;
Line_2 l_i;
Line_2 l_j;
void createNode(Line_2 i, Line_2 j) {
l_i = i;
l_j = j;
Point_2 tmp = Point_2(v_ij.x() - 1, v_ij.y());
if(CGAL::compare_y_at_x(tmp, l_i, l_j) == CGAL::SMALLER) {
Line_2 l_k = l_i;
l_i = l_j;
l_j = l_k;
public:
Node(Point_2 p, Line_2 i, Line_2 j) {
createNode(i,j);
v_ij = Point_2(p.x(), p.y());
createNode(i,j);
v_ij = intersection(i, j);
Point_2 point() const {
return v_ij;
Line_2 i() const {
return l_i;
Line_2 j() const {
return l_j;
bool operator==(const Node& x) const;
bool Node::operator==(const Node& x) const {
bool b = (v_ij == x.point()); /* ERROR */
return (v_ij.x() == x.point().x() && v_ij.y() == x.point().y() && l_i
== x.i() && l_j == x.j());
I got a segmentation fault trying to compare two nodes, the line "bool b ..."
has been isolated from the return statement to find the error which seems to
be
in that operation. This is the backtrace of gdb:
#0
CGAL::Lazy_rep_1<CGAL::Object_cast<CGAL::Point_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
> > >, CGAL::Object_cast<CGAL::Point_2<CGAL::Simple_cartesian<CGAL::Gmpq> > >,
CGAL::Cartesian_converter<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > >,
CGAL::Lazy<CGAL::Object, CGAL::Object, CGAL::Gmpq,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >::update_exact
(this=0x81508a0)
at /usr/local/include/CGAL/Handle_for.h:125
#1 0x080ede78 in
CGAL::Lazy_rep_1<CGAL::CartesianKernelFunctors::Compute_y_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::CartesianKernelFunctors::Compute_y_2<CGAL::Simple_cartesian<CGAL::Gmpq>
>, CGAL::To_interval<CGAL::Gmpq>,
CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
>::update_exact
this=0x814e370) at /usr/local/include/CGAL/Lazy.h:236
#2 0x08103d5f in
CGAL::Lazy_rep_3<CGAL::CartesianKernelFunctors::Construct_point_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::CartesianKernelFunctors::Construct_point_2<CGAL::Simple_cartesian<CGAL::Gmpq>
>, CGAL::Cartesian_converter<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Return_base_tag, CGAL::Lazy_exact_nt<CGAL::Gmpq>,
CGAL::Lazy_exact_nt<CGAL::---Type <return> to continue, or q <return> to
quit---
Gmpq> >::update_exact (this=0x81505f8) at /usr/local/include/CGAL/Lazy.h:236
#3 0x08112178 in
CGAL::Filtered_predicate<CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::Exact_converter<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > >,
CGAL::Simple_cartesian<CGAL::Gmpq> >,
CGAL::Approx_converter<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> > >,
true>::operator()<CGAL::Point_2<CGAL::Lazy_kernel<CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > >,
CGAL::NT_converter<CGAL::Gmpq, CGAL::Interval_nt<false> > > > > > (
this=0xbfc6211c,
a1=@0x814e3e0,
a2=@0xbfc62130)
#4 0x080c6c64 in Node::operator== (this=0x814e3e0,
x=@0xbfc621ac)
---Type <return> to continue, or q <return> to quit---
at /usr/local/include/CGAL/Kernel/global_functions_2.h:742
#5 0x080c756b in erase
(V=@0xbfc62528,
n=@0xbfc621ac)
at /home/marco/Desktop/cgal.project/arrangement.cpp:707
#6 0x080c762b in deleteNode
(V=@0xbfc62528,
Q=@0xbfc62484,
n=@0xbfc62240)
at /home/marco/Desktop/cgal.project/arrangement.cpp:716
#7 0x080c86ed in update_sweepline
(V=@0xbfc62528,
D=@0xbfc62540,
Q=@0xbfc62484)
at /home/marco/Desktop/cgal.project/arrangement.cpp:609
#8 0x080c9ec8 in algorithm_1
(lines=@0xbfc62878,
k=1)
at /home/marco/Desktop/cgal.project/arrangement.cpp:477
#9 0x080d0795 in main (argc=Cannot access memory at address 0x1
Thanks in advance for any answer. Best regards
  • [cgal-discuss] point compare problem [update_exact()], Sterpa, 10/20/2009
