cgal-discuss - [cgal-discuss] problem with CGAL instalation
  • To:
  • Subject: [cgal-discuss] problem with CGAL instalation
  • Date: Tue, 20 Oct 2009 02:04:38 -0700 (PDT)
hi ,
I am the beginner.
I am trying to insatlling CGAL3.4 for windows using the instruction given
in the URL:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
When i configure using cmake-gui . , i got the following error and warning:
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=4
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=3
CGAL_SOVERSION =3.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
CMake Warning (dev) at CMakeLists.txt:88 (include):
Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH
and POP. Run "cmake --help-policy CMP0011" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
The included script
C:/CGAL/CGAL-3.4/cmake/modules/CGAL_Common.cmake
affects policy settings. CMake is implying the NO_POLICY_SCOPE option for
compatibility, so the effects are applied to the including context.
This warning is for project developers. Use -Wno-dev to suppress it.
Targetting Visual Studio 9 2008
Target build enviroment supports auto-linking
Using VC90 compiler.
Generator uses intermediate configuration directory: $(OutDir)
USING CMake version: 2.6.4
System: Windows
Build type: Debug
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /D_DEBUG /MDd /Zi /Ob0
/Od /RTC1'
USING LDFLAGS = ' '
GMP include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
GMP libraries:
GMP definitions:
USING GMP_VERSION = '4.2.4'
MPFR include: C:/CGAL/CGAL-3.4/auxiliary/gmp/include
MPFR libraries:
MPFR definitions:
USING MPFR_VERSION = '2.3.2'
Boost include: C:/boost/boost_1_38
Boost libraries:
optimized;C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-1_38.lib;debug;C:/boost/boost_1_38/lib/libboost_thread-vc90-mt-gd-1_38.lib
Boost definitions:
USING BOOST_VERSION = '1.38.0'
CMAKE_INSTALL_PREFIX=C:/Program Files/CGAL
Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
OpenGL include:
OpenGL libraries: glu32;opengl32
NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will
not be activated.
CGAL_Qt3 needs Qt3, cannot be configured.
CMake Error at cmake/modules/FindQt4.cmake:783 (MESSAGE):
It appears you're trying to use Visual Studio with Qt built by mingw
Call Stack (most recent call first):
src/CGALQt4/CMakeLists.txt:18 (find_package)
Configuring incomplete, errors occurred!
Please help me to Solve this problem.
Kind Regrads,
Arun Kr. Pratihast
ITC
View this message in context:
http://www.nabble.com/problem-with-CGAL-instalation-tp25971260p25971260.html
