cgal-discuss - [cgal-discuss] Cmake does not identify MPFR
  • To:
  • Subject: [cgal-discuss] Cmake does not identify MPFR
  • Date: Fri, 23 Oct 2009 13:58:39 -0600
Hi,
I was trying to install CGAL 3.4, Cmake does not identify MPFR library which is already installed. Due to this, there are further errors being generated when I call make.
I tried with CGAL 3.5 as well and had the same problem.
[rkavalap@onyx CGAL-3.4]$ cmake -DCMAKE_INSTALL_PREFIX=$HOME/Download
-- CGAL_MAJOR_VERSION=3
-- CGAL_MINOR_VERSION=4
-- CGAL_BUILD_VERSION=
-- CGAL_SONAME_VERSION=3
-- CGAL_SOVERSION     =3.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
CMake Warning (dev) at CMakeLists.txt:88 (include):
  Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH
  and POP.  Run "cmake --help-policy CMP0011" for policy details.  Use the
  cmake_policy command to set the policy and suppress this warning.
  The included script
    /home/students/rkavalap/Download/CGAL-3.4/cmake/modules/CGAL_Common.cmake
  affects policy settings.  CMake is implying the NO_POLICY_SCOPE option for
  compatibility, so the effects are applied to the including context.
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Targetting Unix Makefiles
-- Using /usr/lib/ccache/c++ compiler.
-- USING CMake version: 2.6.4
-- System: Linux
-- USING GCC_VERSION = '4.3.2 20081105 (Red Hat 4.3.2-7)'
-- Using gcc version 4 or later. Adding -frounding-math
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
-- GMPXX include:    /usr/include
-- GMPXX libraries:  /usr/lib/libgmpxx.so
-- Could NOT find MPFR
CGAL GMP support needs MPFR. GMP will not be supported.
-- Boost include:     /usr/include
-- Boost libraries:   /usr/lib/libboost_thread-mt.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.34.1'
-- CMAKE_INSTALL_PREFIX=/home/students/rkavalap/Download
-- OpenGL include:     /usr/include
-- OpenGL libraries:   /usr/lib/libGLU.so;/usr/lib/libGL.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libX11.so;/usr/lib/libXext.so
-- USING ZLIB_VERSION = '1.2.3'
-- ZLib   include:     /usr/include
-- ZLib   libraries:   /usr/lib/libz.so
-- USING OPENGL_VERSION = '2.1'
-- USING QT_VERSION = '3.3.8b'
-- OpenGL definitions:
-- Qt3 include:        /usr/lib/qt-3.3/include
-- Qt3 libraries:      /usr/lib/qt-3.3/lib/libqassistantclient.a;/usr/lib/qt-3.3/lib/libqt-mt.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libX11.so;/usr/lib/libXext.so;dl;-lpthread
-- Qt3 definitions:    -DQT_SHARED;-DQT_NO_DEBUG;-DQT_THREAD_SUPPORT;-D_REENTRANT
-- moc executable:     /usr/lib/qt-3.3/bin/moc
-- uic executable:     /usr/lib/qt-3.3/bin/uic
-- USING QT4_VERSION = '4.5.2'
-- Qt4 include:        /usr/include
-- Qt4 libraries:      optimized;/usr/lib/libQtOpenGL.so;debug;/usr/lib/libQtOpenGL_debug.so;-lGLU -lGL;optimized;/usr/lib/libQtGui.so;debug;/usr/lib/libQtGui_debug.so;/usr/lib/libpng.so;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libXi.so;/usr/lib/libXrender.so;/usr/lib/libXrandr.so;/usr/lib/libXcursor.so;/usr/lib/libXinerama.so;/usr/lib/libXfixes.so;/usr/lib/libfreetype.so;/usr/lib/libfontconfig.so;/usr/lib/libXext.so;/usr/lib/libX11.so;/usr/lib/libm.so;optimized;/usr/lib/libQtCore.so;debug;/usr/lib/libQtCore_debug.so;/usr/lib/libz.so;/usr/lib/librt.so;-lpthread;-ldl
-- Qt4 definitions:    -DQT_DLL
-- moc executable:     /usr/lib/qt4/bin/moc
-- uic executable:     /usr/lib/qt4/bin/uic
-- Configuring done
-- Generating done
-- Build files have been written to: /home/students/rkavalap/Download/CGAL-3.4
[rkavalap@onyx CGAL-3.4]$ /usr/lib/libmp
libmp4v2.so.0       libmpcdec.so.5      libmpfr.so.1        libmp.so            libmp.so.3.1.11
libmp4v2.so.0.0.0   libmpcdec.so.5.0.2  libmpfr.so.1.1.2    libmp.so.3
Rahul Kavalapara
