- To:
- Subject: Re: [cgal-discuss] Cmake does not identify MPFR
- Date: Sat, 24 Oct 2009 17:11:22 -0600
please check whether the MPFR header files are installed.
You are right header files were missing. I figured that out after I sent the email. Thanks Joachim.
Rahul Kavalapara
On Sat, Oct 24, 2009 at 3:59 PM, Joachim Reichel <> wrote:
Hi,[...]
> I was trying to install CGAL 3.4, Cmake does not identify MPFR library which
> is already installed. Due to this, there are further errors being generated
> when I call make.
> I tried with CGAL 3.5 as well and had the same problem.
> [rkavalap@onyx CGAL-3.4]$ cmake -DCMAKE_INSTALL_PREFIX=$HOME/Download
> -- GMPXX include: /usr/include> CGAL GMP support needs MPFR. GMP will not be supported.*
> -- GMPXX libraries: /usr/lib/libgmpxx.so
> *-- Could NOT find MPFR
> /home/students/rkavalap/Download/CGAL-3.4> [rkavalap@onyx CGAL-3.4]$ /usr/lib/libmp*
> *[rkavalap@onyx CGAL-3.4]$ /usr/lib/libmp
> libmp4v2.so.0 libmpcdec.so.5 libmpfr.so.1
> libmp.so libmp.so.3.1.11
> libmp4v2.so.0.0.0 libmpcdec.so.5.0.2 libmpfr.so.1.1.2
> libmp.so.3
Joachim
- [cgal-discuss] Cmake does not identify MPFR, Rahul Kavalapara, 10/23/2009
- Re: [cgal-discuss] Cmake does not identify MPFR, Joachim Reichel, 10/24/2009
- Re: [cgal-discuss] Cmake does not identify MPFR, Rahul Kavalapara, 10/25/2009
