- To:
- Subject: Re: [cgal-discuss] Error in CGAL
- Date: Mon, 26 Oct 2009 17:25:57 +0200
On Monday 26 October 2009 16:03:49 Sascha Räsch wrote:
> Hallo,
> I suppose I've found an error in CGAL. The header file
> "AABB_intersections/Bbox_3_bbox_3_do_intersect.h"
> contains a declaration of the function "do_intersect".
> The problem was, that after including the header file twice in my project
> I got a linker error, because "do_intersect" occurred twice as a symbol
> in my object files.
> That is caused by the fact, that "do_intersect" is defined as a symbol
> in the header file and hence
> the header cannot be included twice in the whole project.
You are right. As a temporary workaround, you can qualify the declaration of
that function with "inline".
Laurent Rineau, PhD
- [cgal-discuss] Error in CGAL, Sascha Räsch, 10/26/2009
- Re: [cgal-discuss] Error in CGAL, Laurent Rineau (GeometryFactory), 10/26/2009
