Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
- To:
- Subject: Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection
- Date: Mon, 26 Oct 2009 17:04:09 +0100
Hi,
Eric Berberich wrote:
Andre Massing wrote:
Hi again,
sorry for bothering again the cgal-ml, but this time I came up with a rather simple example, where the Simple_cartesian<double> kernel
See my very recent emails on this list concerning 'double arithmetic' and Andreas Fabri's trick with the
CGAL::Exact_predicates_exact_constructions_kernel
Yes, I know that doubles are evil and not suited for excact predicates because of round-off errors etc.
My question is rather why in aforementioned implementation in the Triangle_3_Tetrahedron_3_intersection.h file the k.bounded_side_3_object() is *not* used for the intersection detection: If it is detected that one vertex lies either on the boundary in the inside of the tetrahedron, why it is not stated as an intersection between the triangle and the tetrahedron? (of course, it might or might not be a real intersection in the SimpleCartesian Kernel case, but it is anyway outside the scope of the kernel to verify it).
At least it would still work fine in the CGAL::Exact_predicates_exact_constructions_kernel
but additionally catch some "corner cases" which are not detected by the
Triangle_3 - Triangle_3 intersection in the SimpleCartesian.
Kind regards,
Andre
- [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Stephane Tayeb, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Camille Wormser, 10/14/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Andre Massing, 10/26/2009
- Re: [cgal-discuss] failed intersection detection for triangle_3 tetrahedron_3 intersection, Eric Berberich, 10/26/2009
