- To: <>
- Subject: RE: [cgal-discuss] CGAL Intersection Error
- Date: Mon, 26 Oct 2009 10:25:26 -0600
-----Original Message-----
[mailto:]
Sent: Sunday, October 25, 2009 5:51 PM
To:
Subject: Re: [cgal-discuss] CGAL Intersection Error
Flaminigo wrote:
> I use
> OutputIterator
> intersection ( Polygon_2<Kernel, Container> p1,
> Polygon_2<Kernel, Container> p2,
> OutputIterator oi)
> to compute intersection of two polygons. How ever it reports errors
when
> computing the following two data:
> Point data [] = {
> Point
(0.0779032708430652393039039793621,0.122371377632631991860812092909
> Point (13.2581684036192424258615574217,
0.959769766188581341381791389722
> Point (1.83288664437794701633777094685
,0.617138373712451504538023527857
> Point (0.693014198934081226965986388677
,0.39778520059801764086060416048
> Point (0.463650350407879274783340406429
,0.340347544290135750610915010839
> Point (0.0922023183796141926338307825972,
> 0.229473196453353733836877381691),
> Point( 0.0727179173985912918887208888918
> ,0.195167801755973285837697517309)
> Polygon p2(data, data + 4);
> Point points_b[] = { Point(0,0), Point(10,0), Point(10,20),
Point(0,20)};
> Polygon p1 (points_b, points_b+4);
> std::ostringstream ostr(std::ostringstream::out);
> std::ostream_iterator<Polygon_h> sit = ostr;
> intersection(p1, p2, sit);
> My kernel is
> typedef CGAL::Cartesian<double> K;
> typedef CGAL::Polygon_2<K>
Polygon;
> typedef CGAL::Polygon_with_holes_2<K>
Polygon_h;
> The error is
> CGAL error: assertion violation!
> Expr: *slIter == curve
> File: /usr/include/CGAL/Basic_sweep_line_2.h
> Line: 675
> Explanation:
> terminate called after throwing an instance of
'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Line: 675
> Aborted
doubles are evil for geometry - as we deal with non-continuous functions
that are in (near-)degenerate cases (probably here as well) extremely
sensitive because of double's rounding.
Please check http://www.cgal.org/philosophy.html or
http://www.mpi-inf.mpg.de/~kettner/proj/NonRobust/index.html for the
anatomy of 'double' "arithmetic" in geometric settings.
eriC
- [cgal-discuss] CGAL Intersection Error, Flaminigo, 10/26/2009
- Re: [cgal-discuss] CGAL Intersection Error, Eric Berberich, 10/26/2009
- RE: [cgal-discuss] CGAL Intersection Error, Dave McVicar, 10/26/2009
