- To:
- Subject: Re: [cgal-discuss] vd.file_output
- Date: Tue, 27 Oct 2009 23:20:21 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Rn200uwQAAYS3u/NXNcLIyb3RX2PH2tqJjA0RAUyo7Ox2waGT2sDkaqdhW203MMYDk yau8F8fBNfxhK33IOL2rK1IcWEWI/GGBLuSsBs2C7f2XZruXGQEXPm7Hmq/SWn6KfK5H WqeWaUutWvrkbUStuzExhEVZYT0pLUKcSjC2s=
Well, there is face traversing iterator defined in VD. You can traverse each face one by one. In each face, there is a vertex iterator. So you can traverse vertices of a specified face one by one. Please refer to http://www.cgal.org/Manual/last/doc_html/cgal_manual/Voronoi_diagram_2_ref/Class_Voronoi_diagram_2.html#Cross_link_anchor_1343 .
Regards
Flaminigo
On Tue, Oct 27, 2009 at 7:21 PM, Marcos R. P. <> wrote:
Thanks, Mr. Flaminigo!Do you know how could I get all vertices of all faces individually?Marcos.
De: Flaminigo <>Enviadas: Seg, Outubro 26, 2009 10:27:33 PM
Para:
Assunto: Re: [cgal-discuss] vd.file_output
It output is the dual graph of VD. The dual graph is a Delaunary Triangulation. So output are full of triples. ...
On Tue, Oct 27, 2009 at 8:52 AM, 顺子 <> wrote:
在2009-10-25,"Marcos R. P." <> 写道:
Hi!Please, what means this output that one obtains with vd.file_output:8 12 2
0 0
100 0
100 100
0 100
200 0
300 0
350 07 0 3
1 2 3
0 1 4
4 1 3
2 1 0
0 4 3
2 5 3
2 0 5
5 6 3
5 0 6
6 7 3
6 0 75 10 11
6 3 4
3 5 4
1 5 2
2 7 1
3 0 2
8 1 7
9 6 4
10 6 9
11 8 7
0 8 11
0 10 9
Thanks!
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
看陆川杨幂新片《琴棋书画》,品网易3D国韵网游《天下贰》
- [cgal-discuss] vd.file_output, Marcos R. P., 10/24/2009
- Re:[cgal-discuss] vd.file_output, 顺子, 10/27/2009
- Re: [cgal-discuss] vd.file_output, Flaminigo, 10/27/2009
- Res: [cgal-discuss] vd.file_output, Marcos R. P., 10/27/2009
- Re: [cgal-discuss] vd.file_output, Olivier Devillers, 10/27/2009
