- To: "" <>
- Subject: RE: [cgal-discuss] Moving generator on VD
- Date: Tue, 27 Oct 2009 11:25:57 -0400
- Accept-language: fr-CA, en-CA
- Acceptlanguage: fr-CA, en-CA
Hi, First make sure that CGAL has not the deletion operation(I think
it should be there). Otherwise take the algorithm described in M. Mostafavi’s
thesis (2002). Select the site first by CGAL site selection function and implement
the algorithm described above. M. M From: Flaminigo [mailto:] Hi, Do you mean the publication "Delete
and insert operations in Voronoi/Delaunay methods and applications"?
However, I don't know how to craft this operation with CGAL interfaces
effectively. I've also read the thread http://www.nabble.com/Voronoi-Diagram-Site-Deletion-td25811594.html.
But the method is not what I want. Because the dual() operation will cost me
too much. Could you show me some small examples written in CGAL? or
some links to related documentation. Thanks very much. Regards On Tue, Oct 27, 2009 at 10:24 PM, Mir Abolfazl Mostafavi
wrote: Hi, There a few alternatives to
move a generator in Voronoi diagram. In addition to CGAL, you may refer to the
work done by Mir Mostafavi at Laval University in Canada and Christ Gold works
in UK. Regards M. M. From: Flaminigo [mailto:] Hi,
I have some generators which has already been used to generate an voronoi
diagram. However, I want to move the position of a generator. Instead of
recomputing all the Voronoi Diagram, I want to know whether there is a good
alternative. |
- [cgal-discuss] Moving generator on VD, Flaminigo, 10/27/2009
- RE: [cgal-discuss] Moving generator on VD, Mir Abolfazl Mostafavi, 10/27/2009
- Re: [cgal-discuss] Moving generator on VD, Flaminigo, 10/27/2009
