cgal-discuss - [cgal-discuss] limiting make_conforming_delauney_2
  • To:
  • Subject: [cgal-discuss] limiting make_conforming_delauney_2
  • Date: Tue, 27 Oct 2009 18:06:11 -0400
Hi,
I'm using make_conforming_delauney_2 to "even out" the slivery triangles in my constrained delauney triangulation.
It works great...except...it inserts a ton of vertices (and rightfully so based on its goal of making a true delauney traingulation) when I could live with only some of the vertices.
Is there an existing hook or way to customize the class to either:
- Limit the level of refinement to some arbitrary maximum or
- Replace the "locally conforming" template entirely (with something different)?
It doesn't appear that there are template arguments other than my CDT for the main "conformer" class, but I would like to reuse its infrastructure.
(Should I just dive in and start using the "refiner" myself?)
cheers
Ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
  • [cgal-discuss] limiting make_conforming_delauney_2, Ben Supnik, 10/27/2009
