- To:
- Subject: Re: [cgal-discuss] Voronoi Diagram Site Deletion
- Date: Tue, 27 Oct 2009 17:16:23 -0700 (PDT)
Hi,
Do you know how to delete sites effectively in VD now? I also face the
similar problem. Please tell me a solution if possible. Thanks
NaiveBug wrote:
> Hi,
> I am pretty new to CGAL. I needed to implement Voronoi Diagrams(VD). But
> the
> documentation of the Voronoi_diagram_2<DG,AT,AP> class does not seem to
> mention a way to DELETE sites from it.
> A Delaunay Graph allows Site Deletion but converting a VD to its dual and
> back
> will make my algorithm very inefficient.
> Is there something that I am overlooking ?
> Thank you all.
> Navneet.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
View this message in context:
http://www.nabble.com/Voronoi-Diagram-Site-Deletion-tp25811594p26087341.html
- [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/08/2009
- RE : [cgal-discuss] Voronoi Diagram Site Deletion, Mir Abolfazl Mostafavi, 10/08/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/09/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/09/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/11/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/16/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/11/2009
- Re: [cgal-discuss] Voronoi Diagram Site Deletion, Flaminigo, 10/28/2009
