Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?
- To:
- Subject: Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?
- Date: Wed, 04 Nov 2009 13:49:32 +0100
Shuchu Han wrote:
Thanks a lot! And I have another question :P
Hi
Currently, I try to represent several shell structured tetrahedral meshes that has two boundary surface. for example, a thin-wall sphere.
I am not sure I fully understand your needs, but I guess that the CGAL 3D mesh generation package could help you more than the 3D triangulation package alone.
I am using the incremental build method from the un-documented method described in " CGAL\Triangulation_incremental_builder_3.h"; Although it can not pass the "is_valid()" test, it works quite fine. my code can iterative visit the edges, cells and vertices;
however, problems occur recently when i handle a shell structured tetrahedral mesh which has shape edges. specifically, it has two boundaries, and each of them has polycube shape ( i got the surface mesh by polycube mapping).
When my old code iterative visit the finite edges of such a shell tetrahedral mesh, it seems jump into an infinite loop for looking the next edge. (when use Triangulation_3::Finite_edges_iterator);
well, if your triangulation does not pass the is_valid() test, there is a high probability that things don't work...
Sir, would u mind to give me an explanation about the theory of Edges of CGAL::Triangulation_3? or recommend some papers about this. And Is there any correct method to build a Triangulation_3 from an input file?
No need to look at papers, the CGAL manual of CGAL::Triangulation_3 (both user and reference manual) should be enough.
Best regards,
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Shuchu Han, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Monique Teillaud, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Shuchu Han, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Monique Teillaud, 11/04/2009
