Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?
- To:
- Subject: Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?
- Date: Fri, 6 Nov 2009 02:17:23 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=JlhmOURzd7h6jooa5XlkNyn3zZyKSbZ3bVQlN8vUG4ABFG/omWDCgAdkEv7PEqhvKE aFXOUI5mfFveazB1G1q8uiHcv3qAfXS6SodST6Z9YS9g2QN6qXEy/0titsTCZL4FPIR6 SFDrdP7y57ilFbL90hcegy4RKFYIbmS4JVGCg=
Thanks a lot! Think i should create the infinite cells by hand.
best regards
shuchu
On Wed, Nov 4, 2009 at 8:49 PM, Monique Teillaud <> wrote:
Shuchu Han wrote:Hi
Thanks a lot! And I have another question :P
I am not sure I fully understand your needs, but I guess that the CGAL 3D mesh generation package could help you more than the 3D triangulation package alone.
Currently, I try to represent several shell structured tetrahedral meshes that has two boundary surface. for example, a thin-wall sphere.
well, if your triangulation does not pass the is_valid() test, there is a high probability that things don't work...
I am using the incremental build method from the un-documented method described in " CGAL\Triangulation_incremental_builder_3.h"; Although it can not pass the "is_valid()" test, it works quite fine. my code can iterative visit the edges, cells and vertices;
however, problems occur recently when i handle a shell structured tetrahedral mesh which has shape edges. specifically, it has two boundaries, and each of them has polycube shape ( i got the surface mesh by polycube mapping).
When my old code iterative visit the finite edges of such a shell tetrahedral mesh, it seems jump into an infinite loop for looking the next edge. (when use Triangulation_3::Finite_edges_iterator);
No need to look at papers, the CGAL manual of CGAL::Triangulation_3 (both user and reference manual) should be enough.
Sir, would u mind to give me an explanation about the theory of Edges of CGAL::Triangulation_3? or recommend some papers about this. And Is there any correct method to build a Triangulation_3 from an input file?
Best regards,
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Shuchu Han, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Monique Teillaud, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Shuchu Han, 11/03/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Monique Teillaud, 11/04/2009
- Re: [cgal-discuss] How to tessellate a cube into tetrahedrons that it can be an valid element in CGAL::Triangulation_3?, Shuchu Han, 11/05/2009
