cgal-discuss - Re: [cgal-discuss] error regarding file stream
  • To:
  • Subject: Re: [cgal-discuss] error regarding file stream
  • Date: Wed, 04 Nov 2009 18:51:52 +0100
Is it here
Bare_point p;
for( ; n>0 ; n--) {
is >> p;
std::cout<< p<<std::endl;
lwp.push_back(p);
that you see this happening?
S.
PS: What we call a minimal example is an exemple we can compile and run
(should also be small and the problem isolated).
pratihast22089 wrote:
hi,
I am facing one simple problem regarding file stream. I have the data file like this:
257507.75 471326.93 44.51
257507.77 471326.90 44.49
257507.89 471326.93 44.04
257507.81 471326.81 44.51
257507.89 471326.87 44.10
While Reading and writing file stream, it truncate the number behind
point of first two columns but not for the third column.
output:
257507 471326 44.51
257507 471326 44.49
257507 471326 44.04
257507 471326 44.51
257507 471326 44.10
I had included the #include <CGAL/double.h> header file.
Could you please help me in this regrads.
Thank you in advance.
Regards,
Arun K Pratihast
Hello,
Could you please post a minimal example so that we can reproduce the problem encountered.
S.
hi,
Here is my code:
#include "stdafx.h"
#include <cassert>
#include <vector>
#include <fstream>
#include <CGAL/Weighted_alpha_shape_euclidean_traits_3.h>
#include <CGAL/Regular_triangulation_3.h>
#include <CGAL/Alpha_shape_3.h>
#include <list>
#include <cassert>
#include <vector>
#include <fstream>
#include <utility>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Weighted_alpha_shape_euclidean_traits_3<K> Gt;
typedef CGAL::Alpha_shape_vertex_base_3<Gt> Vb;
typedef CGAL::Alpha_shape_cell_base_3<Gt> Fb;
typedef CGAL::Triangulation_data_structure_3<Vb,Fb> Tds;
typedef CGAL::Regular_triangulation_3<Gt,Tds> Triangulation_3;
typedef CGAL::Alpha_shape_3<Triangulation_3> Alpha_shape_3;
typedef Alpha_shape_3::Alpha_iterator Alpha_iterator;
typedef Alpha_shape_3::Cell_handle Cell_handle;
typedef Alpha_shape_3::Vertex_handle Vertex_handle;
typedef Alpha_shape_3::Facet Facet;
typedef Alpha_shape_3::Edge Edge;
typedef Gt::Weighted_point Weighted_point;
typedef Gt::Bare_point Bare_point;
typedef K::Point_3 Point;
typedef std::list<Vertex_handle>::const_iterator Vl_it;
int main()
std::list<Weighted_point> lwp;
//read input
std::ifstream is("D:/Cgalcode/Polyhedronification/Debug/demo.xyz");
int n;
is >> n;
std::cout << "Point Reading Start:" << n << " points " << std::endl;
Bare_point p;
for( ; n>0 ; n--) {
is >> p;
lwp.push_back(p);
std::cout << "Point Reading End:" << std::endl;
Alpha_shape_3 as(lwp.begin(), lwp.end(), 0.5,
Alpha_shape_3::GENERAL);
//Alpha_shape_3 as(lwp.begin(), lwp.end(),
Alpha_shape_3::GENERAL);;
Alpha_iterator aa = as.alpha_upper_bound(1);
as.set_alpha(*aa);
//build alpha_shape in GENERAL mode and set alpha=0.15
//Alpha_shape_3 as(lwp.begin(), lwp.end(), 0.015,
//explore the 0.15-shape - It is dual to the boundary of the union.
std::list<Cell_handle> cells;
std::list<Facet> facets;
std::list<Edge> edges;
as.get_alpha_shape_cells(std::back_inserter(cells),Alpha_shape_3::INTERIOR);
as.get_alpha_shape_facets(std::back_inserter(facets),
Alpha_shape_3::REGULAR);
Alpha_shape_3::SINGULAR);
as.get_alpha_shape_edges(std::back_inserter(edges), Alpha_shape_3::SINGULAR);
std::cout << " The 0.15-shape has : " << std::endl;
std::cout << cells.size() << " interior tetrahedra" << std::endl;
std::cout << facets.size() << " boundary facets" << std::endl;
std::cout << edges.size() << " singular edges" << std::endl;
std::list<Vertex_handle> al_vs;
as.get_alpha_shape_vertices(back_inserter(al_vs),Alpha_shape_3::REGULAR);
//as.get_alpha_shape_vertices(back_inserter(al_vs),Alpha_shape_3::SINGULAR);
std::cout << al_vs.size() << " Vertex Size" << std::endl;
//Appending my code
std::cout << " My alpha point " << std::endl;
std::ofstream of;
of.open("D:/Cgalcode/Polyhedronification/data/arun/out_test1.xyz" );
for(Vl_it it=al_vs.begin();it!=al_vs.end(); it++) {
std::cout <<(*it)->point()<< std::endl;
of<<(*it)->point()<<"\n";
return 0;
